Get "default port unable to find object in the DB" error of InfinityProgram object when performing "Send To" --> "Text File" for controller.
  • Get "default port unable to find object in the DB" error of InfinityProgram object when performing "Send To" --> "Text Fil...
  • Dave_Shore
    Dave_Shore
  • SangKim
    SangKim
‎2018-09-06 01:41 PM
Error message of "default port unable to find object in the DB" from InfinityProgram objects when trying to export the controller to a dump file backup by performing "Send To" --> "Text File" from workstation.
Continuum Workstation (LAN & SU)
NetController (CX99xx, CX96xx, CX97xx)
InfinetController (i2xxx , i1 controllers)
The controller was created by importing a dump file created from different system DB or by importing a dump file from a different type of controller followed by poor/incorrect modification.
Recreate the InfinityProgram object again manually as below.
  1. Copy the source code of the InfinityProgram in a text file.
  2. Delete the InfinityProgram from Continuum.
  3. Create a new InfinityProgram with the same name.
  4. Paste the source code from the text file into the InfinityProgram editor, save the InfinityProgram.
Tags (2)
  • 5436
  • defaultport
