Get "Untranslated error" when adding a point under a B3 controller.
  • Get "Untranslated error" when adding a point under a B3 controller.
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 10:34 AM
Get error message "Untranslated error" when adding a point under a B3 controller.
StruxureWare Building Operation version 1.3
Automation Server version 1.3
A new B3 controller was added to the AS via "Learn"
Manually add the B3 controller to the AS.
  • 12789
