Generate a serial number for a downloaded copy of the WorkPlace Tech Tool software
  • Generate a serial number for a downloaded copy of the WorkPlace Tech Tool software
  • CraigEl
    CraigEl
  • sesa116868
    sesa116868
‎2018-09-06 02:17 PM
Last Updated: Administrator CraigEl Administrator ‎2023-04-23 11:14 PM
Downloaded the WPT (WorkPlace Tech Tool) software.  How do I get a serial number so that I can complete the licensing form displayed with the "Purchase WorkPlace tech Software" program?
TAC IA Series
WorkPlace Tech Tool 5.x.x
The WPT license generator program requires a "WIBS serial number" so that the license request can be generated. If the field is left blank, the program will not allow the license request to be generated.
The serial number is provided on purchased CDs so as to provide a method of tracing the manufactured CDs. To license the downloaded version of the Workplace Tech Tool software, you must enter an 8 digit serial number.  It is suggested, although not required, that you enter the current date as the serial number. When using the date as the serial number, enter the four digit year followed by the two digit month followed by the two digit day, i.e., in the format YYYYMMDD. For example, 20230203.
  • TAC IA Series
Tags (2)
  • 4334
  • CraigEllis23
100% helpful (1/1)
