From the Monitor (the main MPM), I can pick up values from other MPM, but the other MPM could not pick up values from the Monitor.
  • From the Monitor (the main MPM), I can pick up values from other MPM, but the other MPM could not pick up values from the Mon...
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 09:21 AM
From the Monitor (DEV100) it is possible to pick up values from other MPMs, by the use of an LUA script.
Example:
ME.AV1 = DEV200.AV1
But, it is not possible for another device to pick up values from the Monitor (DEV100) device.
MPM
The Monitor device (DEV100) could see all other MPM in the network, and therefore could get values from other devices.
Other devices will only see devices that are below itself in the tree structure, and will therefore not be able to get values from the Monitor device.
The Monitor device (DEV100) have to handle all the transfers of variables both from MPM below, as well as sending variables to MPM devices below in the tree structure.
Example:
ME.AV1 = DEV200.AV1
DEV200.AV2 = ME.AV2
  • EcoStruxure Building Expert
  • 16957
