Forced inputs in Xenta 121s return to default values
  • Forced inputs in Xenta 121s return to default values
  • Cody_Failinger
    Cody_Failinger
‎2018-09-06 03:01 PM
  • LonMaker
  • NL220
Every time you hit "Apply" or "OK" in Zbuilder, the Xenta 121 will get a reset command. When the controller receives the reset command, the inputs lose their forced status and return to default values.
After the Xenta 121 controller has been rest, the overridden points must be forced again.
  • 2364
