Folders have disappeared from navigation pane in folder explorer
  • Folders have disappeared from navigation pane in folder explorer
  • Taylor_Leach
    Taylor_Leach
  • Cody_Failinger
    Cody_Failinger
Commander Taylor_Leach Commander
‎2018-10-31 12:37 PM
With revision 1.0.37 and later, folders under the instance within the navigation tree are no longer there.
Access Expert
  • V3 Hosted
The 1.0.37 release of the Keep software removed the folders under the instance within Folder Explorer.
Use the corresponding tabs at the top of the window.
  • EcoStruxure Access Expert
