First object in a Sigma IC3-SNP always displays it's default value
  • First object in a Sigma IC3-SNP always displays it's default value
  • CraigEl
    CraigEl
‎2018-09-10 11:29 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-23 12:32 AM
In Sigma System Manager, the object associated with the first entry in the Gateway.txt file of an S-IC3-SNP integration controller consistently displays its default value, rather than the expected mapped value.
Satchwell BAS & Sigma
Sigma IC3-SNP
This issue arises due to the way the S-IC3-SNP controller processes the object mapping file (Gateway.txt). Specifically, the first line in the file is not correctly interpreted, causing the first object to revert to its default value.
Note: This behavior does not affect earlier versions such as S-IC-SNP.
Steps to Resolve:
  1. Edit the Gateway.txt file.
  2. Insert a dummy line at the beginning of the file.
    This placeholder prevents misinterpretation of the first actual object.
    Example
    Original Gateway.txt:
    51,13,R,114,2,0,0,3,1 ;Room temperature
    52,13,R,114,28,0,0,3,1 ;PIR Status
    53,13,R,160,6,0,0,3,1 ;Heating Valve Open
    Revised Gateway.txt with Dummy Line:
    51,13,R,114,2,0,0,3,1 ;Dummy text entry
  1. Save and reload the configuration in Sigma System Manager.
✅ The first object should now display its correct mapped value.
  • Satchwell BAS & Sigma
Tags (2)
  • 11899
  • CraigEllis25
