File Preparation in Visio to Correct Workplace Tech and Workplace Tech Editor Application Failures
  • File Preparation in Visio to Correct Workplace Tech and Workplace Tech Editor Application Failures
  • JohnBoehmer
    JohnBoehmer
  • RandyDavis
    RandyDavis
JohnBoehmer Schneider Alumni (Retired)
‎2019-11-22 09:17 AM
Workplace Tech or Workplace Tech Editor is crashing when accessing a specific Visio file.
TAC IA Series, EcoStruxure Building Operation
  • I/A Series WorkPlace Tech
  • Building Operation Workstation (Workplace Tech Editor)
There are a number of possible issues with the Visio 2013 and Visio 2016 files when running in Compatibility Mode.  Compatibility Mode is required for Workplace Tech and Workplace Tech Editor since they are both designed to use the older .vsd file format.  The mentioned Visio versions both use .vsdx as a native file format.
[video]
Labels (2)
  • TAC IA Series
Tags (3)
  • crash
  • RandyDavis19
  • workplace tech
100% helpful (1/1)
