File Equalization on a new PC with SP4.
  • File Equalization on a new PC with SP4.
  • Roger_Bently
    Roger_Bently
‎2018-09-06 03:04 PM
Running Equalization on a PC that has SP4 (Service Pack 4) and the clients are unable to connect to the File Master
PC that has SP4
There is a protocol setting that needs to be enabled for this to occur.
The following steps show the path to MSQL Server where the protocol resides and how to get it enabled.
  1. Open Windows Explorer and go to C:\Program Files\Microsoft SQL Server\80\Tools\Binn\SVRNTCN.exe.
  2. Double click on this file and enable the following files, Named Pipes and TCP/IP.
  3. Apply the changes and then close the editor SQL Server Network Utility.
  • TAC INET
  • 2065
