Field Devices - What mains actuator can be used with a VTRA rotary valve?
  • Field Devices - What mains actuator can be used with a VTRA rotary valve?
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-06 10:19 AM
VTRA
Actuator
Mains
Existing actuator has failed and is no longer available.
The replacement actuator and linkage are required;
  • M9B-230 actuator - 860-1020-000
  • Linkage - 860-0990-000
  • Field Devices
  • 13525
