Field Devices - What is the difference between the M1500 and the M1500A actuators?
  • Field Devices - What is the difference between the M1500 and the M1500A actuators?
  • sesa125819
    sesa125819
‎2018-09-06 11:06 AM
Forta
M1500
M1500A
Why has the "A" been dropped from the specification number?
Originally there were two specifications;
M1500A which fitted to the control valve using a "U-Bolt".
M1500A-VB which fitted to the valve using a "Screw Mount".
The M1500 actuator is fitted to the valve using an "U-Bolt", if a "Screw Mount" is required, then the appropriate linkage kit should be used.
  • Field Devices
Tags (4)
  • 11199
  • forta
  • m1500
  • m1500a
