Field Devices - What grade of stainless steel is used in the Satchwell DWA range of sensor pockets?
  • Field Devices - What grade of stainless steel is used in the Satchwell DWA range of sensor pockets?
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-06 10:19 AM
Sensor Pockets
DWA
Satchwell
Customer requires assurance that the stainless steel pockets are the correct grade.
The DWA (Satchwell range) pockets that we sell are made from 316Ti steel. We use 316Ti rather than the 316L because of elevated temperature mechanical strength, pitting corrosion resistance, mechanical polishing and weldability.
  • Field Devices
  • 13523
