Field Devices - DC1100 / DC1400 - Boilers do not operate when HWS output is on.
  • Field Devices - DC1100 / DC1400 - Boilers do not operate when HWS output is on.
  • sesa125819
    sesa125819
‎2018-09-06 12:47 PM
Drayton
DC 1100
DC 1400
Boilers not working
HWS
Hot water
"Boiler Linked" has not been selected in the menu setup.
By default the controller does not have the "Boiler Linked" option set.
Set the rotary switch to "Set".
In the display menu structure choose;
  • "System Menus"
  • "Alter Settings"
  • Enter the pass number of 0112 and press enter.
  • "Hot Water"
  • "Link Option"
  • Choose the "Linked Option".
Return the rotary switch back to "Auto"
  • Field Devices
  • 7128
