Failed to reserve $xbp file in Vista! Error: File object already reserved.
  • Failed to reserve $xbp file in Vista! Error: File object already reserved.
  • Cody_Failinger
    Cody_Failinger
  • Anonymous user
‎2018-09-10 11:09 PM
When trying to open/edit a XBuilder project in workstation the following error is given:
  • TAC Vista Workstation
  • TAC Vista XBuilder
Vista has multiple instances of the same XBuilder project open at the same time. For some reason if a XBuilder project opened from Workstation was not closed normally, workstation will not allow the user to open/edit the XBuilder project.
First, check if there is already a XBuilder window open. If there the same project is already open then close the window. If there is no other XBuilder window open then follow these steps:
  1. Close TAC Vista Workstation and Server
  2. Restart TAC Vista Server and Workstation.
After the reboot the user should be able to open XBuilder editor.
  • 11950
