Factory default IP address for I/A Series G3 JACE-6 or JACE-7
  • Factory default IP address for I/A Series G3 JACE-6 or JACE-7
  • RyanSuar
    RyanSuar
  • WaynePeters
    WaynePeters
‎2018-09-06 12:18 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-08-06 07:32 AM
What is the factory default IP address for a new I/A Series G3 JACE-6 or JACE-7?
TAC IA Series
  • I/A Series G3
  • JACE-6
  • JACE-7
Initial power up and connection to Workbench
Two female 10/100-Mbit Ethernet connections are provided on the JACE-6 and JACE-7 hardware platforms. These are RJ-45 connectors labeled LAN2 and LAN1. Use a standard Ethernet patch cable for connecting to a hub or Ethernet switch. An activity LED for each Ethernet port is visible, and are labeled "LAN2" and "LAN1" on the cover.
The factory-default IP address for LAN1 on the JACE-6 and JACE-7 is 192.168.1.12n, where the last numeral n in the address matches the last digit of the JACE's serial number, and subnet mask is 255.255.255.0. By default, LAN2 on the JACE-6 and JACE-7 is disabled.
The factory default platform username and password is tridium / niagara.
  • TAC IA Series
  • 8020
34% helpful (1/3)
