Facility Code and Card Number size supported by Security Expert
  • Facility Code and Card Number size supported by Security Expert
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
Guinan AdamSteele Guinan
‎2019-08-18 11:30 PM
What is the maximum size Card Number and Facility Code Number supported by Security Expert?
EcoStruxure Security Expert
  • Security Expert Controller
  • Security Expert Smartcard Reader
Adding a card to one of the Card number slots on the General tab of a User page allows for a maximum of a ten-digit facility code and ten-digit card number.
The currently supported size of the Facility/Card number allows a maximum of a ten-digit facility code and ten-digit card number as can be seen below.
Facility/Card NumberFacility/Card Number
This Facility/Card number is entered when adding a credential to a User on the General tab of the User page.
The size of the allowable facility code and card number can be increased beyond ten-digits by using Credential Types instead. Once the Credential Type has been created, it can then be used in the CREDENTIALS section for those users. For additional details on Credential Types see the AN 276 Security Expert - Configuring Credential Types - Integration Guide.
  • EcoStruxure Security Expert
Tags (2)
  • AdamSteele19
  • AdamSteele24
100% helpful (1/1)
