External Log Storage PostgreSQL database schema
  • External Log Storage PostgreSQL database schema
  • Dave_Shore
    Dave_Shore
  • RobertAndriolo
    RobertAndriolo
Dave_Shore Schneider Alumni (Retired)
‎2022-02-02 02:10 AM
Last Updated: Picard RobertAndriolo Picard ‎2022-10-12 04:32 PM
External Log Storage PostgreSQL / TimescaleDB schema.
  • EcoStruxure Building Operation 3.0 and above
Need to understand what is supported with regards to third-party queries to the PostgreSQL / TimeScaleDB
  • The PostgreSQL database schema is not published by R&D (The Report Server schema can be generated via WebReports see Obtaining a Database Schema for EBO WebReports / Report Server - Communities, but should not be compared with External Log Storage)
  • In order to get visual diagrams that show relations of the Extended Log Storage PostgreSQL TimescaleDB, you can download tools such as "SchemaSpy ", ERBuilder, or similar to generate it.
    • Sample outputs are attached from SchemaSpy and ERBuilder.
  • The PostgreSQL database schema is likely to change with each EBO version and hence is not published
  • External Log Storage is designed to operate with EBO, rather than provide data directly to a third party - no support is offered with the third-party connection and data transfer
  • Only third-party read querying is allowed
Most tables are self-explanatory, the "trend_data" table, "Type" column is detailed below:
It's a number representing which record type
TrendRecordTypes =
RecordTypes::s_trendrecordTLogValueRecord,
RecordTypes::s_trendrecordTLogEditValueRecord,
RecordTypes::s_trendrecordTLogCommentRecord,
RecordTypes::s_trendrecordTLogEventRecord,
RecordTypes::s_trendrecordTLogEventValueRecord,
RecordTypes::s_trendrecordTLogMeterChangeRecord,
RecordTypes::s_trendrecordTLogNullEventRecord,
RecordTypes::s_trendrecordTLogReconfigRecord,
RecordTypes::s_trendrecordTransferEventRecord
The record type that is most common is the TLogValueRecord, and it's 0 and so on
For reference, the only other documents available would be
Alarms - Add/Remove Columns Dialog Box (Alarms) (se.com)
Events - Add/Remove Columns Dialog Box (Events) (se.com)
Trends - Add/Remove Columns Dialog Box (Trends) (se.com)
Tags (7)
  • DavidShore22
  • extended logs
  • HernanUruena24
  • Postgres
  • RobertAndriolo22
  • schema. database
  • Timescale
