Obtaining a Database Schema for EBO WebReports / Report Server
  • Obtaining a Database Schema for EBO WebReports / Report Server
Admiral David_Kendrick Admiral
‎2022-03-14 08:36 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:09 AM
Where can you obtain the Database Schema for the EBO WebReports / Report Server Database
Building Operation Report Server
From EBO version 3.2.x WebReports/RS is no longer being developed as we move to External Log Storage with Postgres and Timescale DB.    To allow our customers to continue to work with existing WebReports/RS databases if they so wish, it may be helpful to provide the DB Schema.
An inbuilt Report already exists within WebReports call 'Database Schema' which allows you to select which Tables you would like to see in the WebReports / RS Database
Running this will produce a .pdf Report detailing the RS Database Schema tables, to aid with 3rd Party integrations and other DB manipulation.Schema2.jpg
A full database schema report is attached for reference (Version 3.2.3)
Tags (2)
  • DavidKendrick22
  • RobertAndriolo22
100% helpful (1/1)
