ExtendedLog does not work, Report object shows no logged data, and no extendedlog data are saved in the Database.
  • ExtendedLog does not work, Report object shows no logged data, and no extendedlog data are saved in the Database.
  • SangKim
    SangKim
‎2018-09-10 08:32 AM
AccTrace shows error  "SQLSTATE ERROR CODE: 37000" and "ERROR MESSAGE: [Microsoft][ODBC SQL Server Driver][SQL Server]Failed to load msxmlsql.dll." every extendedlog interval.   The ExtendedLog does not work and no log data are found in the Database.
SQL Server
Cyberstation
NetController.
The "msxmlsql.dll" file has been deleted from SQL server by an anti-virus software or the security setting changes.
Obtain the msxmlsql.dll and msxmlsql.rll files from the SQL Server installation kit.
  • 7167
