Extended Trend Logs stop updating in ES
  • Extended Trend Logs stop updating in ES
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 09:12 AM
The Extended Trend Logs stop updating in Enterprise Server.  When the ES is rebooted the trend logs resume.
Enterprise Server
The Extended Logs Maximum transfer interval is set too low causing it to trigger again before it has managed to finish the last read.
Increase the Maximum transfer interval setting of the Extended Log.
Tags (2)
  • 17279
  • PeterLarsen25
