Export and Import between different versions in EcoStruxure Building Operation
Select a Country
  • Export and Import between different versions in EcoStruxure Building Operation
  • RandyDavis
    RandyDavis
  • Jonas_Brissman
    Jonas_Brissman
Jonas_Brissman Champion
‎2020-04-22 06:02 AM
Last Updated: RandyDavis Champion ‎2020-04-22 06:05 AM
Can an export file from one version of EcoStruxure Building Operation(EBO) be imported to another version of EBO?
Building Operation Workstation
Export files are in general NOT backward compatible. A Script or Function Block Program that is exported from for example version 3.1.x is NOT guaranteed to import successfully into an earlier release
  • Starting in version 3.0.x, import files exported from a later release than where they are imported will be denied. An export file from 3.1.x cannot be imported in 3.0.x. An export file from 3.0.x can however still be imported in 2.0.x, but it's not recommended, and it may fail to import successfully.
  • In version, 3.1.x import files exported from versions older than version 1.3, will be denied.
  • Starting in version 3.2.x, import files exported from versions older than 1.8.x will be denied.
  • JonasBrissman20
100% helpful (2/2)
