Explanation to a Trend Log Comparison Report
  • Explanation to a Trend Log Comparison Report
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 10:39 AM
Where can I find documentation which explains what a Trend Log Comparison Report does?
StruxureWare Building Operation 1.3
The Trend Log Comparison report provides a way for you to compare the output of the trend logs associated with a data point, such as the kilowatts for a power meter. The report provides similar reporting as the Trend Chart, however, you can export the report, schedule the report, and run the report using a Web browser and without access to WorkStation.
It is possible to read about Trend Log Comparison report in the manual Web report reference guide which you find on the Extranet under Products > StruxureWare Building Operation > Product information > StruxureWare > Building Operation 1.3 > Report server.
Tags (2)
  • 12575
  • 148832
100% helpful (1/1)
