Errors When Editing I/A Series R2 UNC Station Database in WorkPlace Pro
  • Errors When Editing I/A Series R2 UNC Station Database in WorkPlace Pro
  • CraigEl
    CraigEl
  • sesa116868
    sesa116868
‎2018-09-06 12:56 PM
Last Updated: Administrator CraigEl Administrator ‎2025-12-10 02:42 PM
Various errors appear in the Standard Output Window when attempting to edit a UNC station database using WorkPlace Pro (WPP). Errors include missing modules and out-of-date modules.
TAC IA Series
I/A Series R2 WPP and UNC.
The engineer’s WPP installation does not match the UNC station configuration.
  • Some modules in WPP are missing or at different revision levels.
  • The NiagaraD service version on the engineer’s computer does not match the version installed on the UNC.
  1. Verify that all modules used in the UNC are present and match the versions in the nre\modules folder of the WPP system.
  2. Ensure the NiagaraD service running on the computer matches the software version installed on the UNC.
  3. If discrepancies exist, update WPP and modules to align with the UNC station configuration.
  • TAC IA Series
Tags (3)
  • 115631
  • 6862
  • CraigEllis25
