Error while creating the Continuum DataBase in 64-bit Operating System
  • Error while creating the Continuum DataBase in 64-bit Operating System
  • CraigEl
    CraigEl
  • Sampath_Konda
    Sampath_Konda
‎2018-09-11 12:29 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 05:41 PM
Error while creating the Continuum DataBase in 64-bit Operating System. SQL Server Installation Package cannot be opened.
Microsoft SQL Server 2005 Setup
SQL Server 2005 Setup cannot continue because the installation package could not be opened.
The installation package has a missing file, or you are running a 32-bit only Setup program
on a 64-bit computer. To continue, verify the SQL Server 2005 package you are running is
supported on WOW64. If you are certain that you are running a supported SQL Server 2005
package, and you continue to see this message, contact the application vendor.
Andover Continuum
  • Continuum 1.93 and below
  • 32-bit Operating Systems
Continuum 1.93 and below versions do not support in 64-bit Operating Systems.
Install Continuum in a supported Operating System.
Read and follow the Continuum compatibility matrix before installing.
Download the Andover Continuum Compatibility from Software and Firmware compatibility matrix for older versions of the traditional product lines.
  • 12361
