Error when trying to activate embedded license
  • Error when trying to activate embedded license
  • Jonas_Brissman
    Jonas_Brissman
  • RobertAndriolo
    RobertAndriolo
Janeway Jonas_Brissman Janeway
‎2023-05-01 07:02 AM
Last Updated: Guinan RobertAndriolo Guinan ‎2024-02-29 10:43 PM
When trying to activate a license in an AS-P/B the following error message was shown and the activation failed:
Online activation:
12:57:24: Executing licensing command
12:57:24: Executing embedded operation: Activate ActivationID: ACT-xxx
12:57:32: Embedded operation: Activate failed: ASEmbeddedAPI internal error: Binary response does not contain feature information Error status information: FNO server response: Z(BACK_OFFICE%DEBACK_OFFICE+']\dBl&%MSM230312018I|B}~%ACT-xxxxx/jlSkkj1%<K!,b7OnpUy7 zqDFG#I$QGGR0:SYWJVGIuW}+iea 0\wR/`;yX'HGX*;;nEl]d0I+nHWh(VD"+a uwpf%XF[N6~!,^?R]y?VPCw\gB{"dSy2K7ph;_=qw.|c]Vp;.nlMbLl-~Z!UY<:=TFZEL~h=\V)>ML)ld0g'PPcjrosy&]p9Y((?II#*B5/U16X;o-
12:57:32: Licensing command completed
12:57:34: Activating licenses failed
Offline activation:
12:56:02: Executing licensing command
12:56:02: Executing embedded operation: ProcessResponseFile ResponseFile: C:\Users\Mitthem\Desktop\Garage\response\xxxxxxx\8ba20b60-b19c-4a5d-8fea-693ef9282c8c.bin
12:56:03: Embedded operation: ProcessResponseFile failed: ASEmbeddedAPI internal error: Binary response does not contain feature information Error status information:
12:56:03: Licensing command completed
12:56:05: Activating licenses failed
  • Building Operation Automation Server Premium (AS-P)
  • Building Operation Automation Server Bundled (AS-B)
  • Building Operation Device Administrator (DA)
  • Embedded Licenses
The reason for the issue was that the number of available licenses for activation was 0, but the error message in DA was not indicating that. The Device Administrator (DA) showed that two licenses were available but were out of sync.
When looking at the Entitlement in DA, it had a yellow dot on it, indicating that it was added offline.
In DA version 5.0.2 and later, DA contacts the License server directly when adding an Entitlement in prior versions this was done through the AS-P.
In DA version 5.0.2 and later, it is enough that the computer where DA is installed has an internet connection when adding an Entitlement online.
After upgrading DA to version 5.0.2 and refreshing the Entitlement, the Device Administrator showed the correct number of available licenses.
If upgrading the site to this version is not possible, the Entitlement ID / Activation ID availability and device list can be verified by using the User Portal FlexNet Login (flexnetoperations.com)
It is also possible to run Device Administrator version 5.0.2 with the concurrent site version used as long as the Servers are at 4.0.4 and above to check, verify and activate licenses.
Important Note: Device Administrator 5.0.3 and above will NOT support lower-version Automation Servers as 5.0.2 does.  This is due to new features of embedded licenses for servers as well as the handling of servers without internet connections.  In this case, ALL servers must run the same version as the Device Administrator version when handling licenses.
Further information on Automation Server Licensing Overview is available through the online WebHelp.
Tags (3)
  • JonasBrissman23
  • RobertAndriolo23
  • RobertAndriolo24
