Error "Setting NeuronID of router" when upgrading a Lonmaker Database to NL220
  • Error "Setting NeuronID of router" when upgrading a Lonmaker Database to NL220
  • PeterLarsen
    PeterLarsen
‎2018-09-07 11:27 PM
When browsing to the LNS database on the new NL220 project screen, an error message says, "Setting NeuronID of router <%s> ..._O"
Other, TAC Vista
  • Lonmaker
  • Newron NL220
The name of the database folder is over 12 characters. For example, C:\LM\Db\367_Collins_St
To correct this error, rename the folder containing the lonworks database to 12 characters or less.
The above example folder name in the Cause heading could be renamed to  C:\LM\Db\367CollinsSt
  • 5099
