Error "ACX database fault" in NetControllers door object access events.
  • Error "ACX database fault" in NetControllers door object access events.
  • sesa119747
    sesa119747
  • AdamSteele
    AdamSteele
‎2018-09-07 06:03 AM
When viewing access events in NetControllers door object, error "ACX database fault".
NetController with AC1 I/O modules
NetController II with AC1 I/O modules
Error is due to the Door Switch, on a dual-reader door, being wired to the Exit reader I/O module. I/O channels on the Exit reader I/O Module should not be used for Door control.
Rewire the Door Switch to the Entry reader I/O Module.
For an example of the correct wiring of a dual-reader door’s Door Switch, please see page 149 of "IO System Reference Guide".
Tags (2)
  • 4315
  • acxdatabasefault
