Error message when you add a new Xenta device to NL220. Lca: Lonmark Self-documentation: Object name too long (Subsystem: NS, #272)
  • Error message when you add a new Xenta device to NL220. Lca: Lonmark Self-documentation: Object name too long (Subsystem: NS,...
  • PeterLarsen
    PeterLarsen
‎2018-09-10 07:55 AM
When you try to insert a new Xenta server into NL220 you receive the error message.
  • NL220
  • XBuilder
Controller Object names are limited to 16 character long.
In X-Builder, under the SNVT folder, rename the Controller object names to less than 16 characters.
  • 8062
