Error message, "taclogdata is not a valid TAC Vista logdatabase" at installation of TAC Vista.
  • Error message, "taclogdata is not a valid TAC Vista logdatabase" at installation of TAC Vista.
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 10:35 AM
Get error message, "taclogdata is not a valid TAC Vista logdatabase" at installation of TAC Vista.
TAC Vista 5.1.0 and later versions.
When installing Vista and using a custom SQL installation a SQL database is specified. If this SQL database is created manually and not by Vista the database will not be recognized as a valid TAC Vista log database.
Let TAC Vista create the SQL database at the installation or use the Vista server setup to create a SQL database.
  • 12729
