Error message "Could not load file or assembly TAC.Common.License.Flex.dll when loading TAC Vista Webstation."
  • Error message "Could not load file or assembly TAC.Common.License.Flex.dll when loading TAC Vista Webstation."
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 10:38 AM
Get error message when loading TAC Vista Webstation:
"Could not load file or assembly TAC.Common.License.Flex.dll or one of it dependencies. The specified module could not be found."
TAC Vista 5.1.4
TAC Vista Webstation 5.1.7
When installing TAC Vista Webstation it must always be the same version as the TAC Vista server.
Upgrade TAC Vista server to version 5.1.7 or downgrade TAC Vista Webstation to version 5.1.4.
  • 12609
