Error message in the Vista event log "system failed to log in on node TAVISTA".
  • Error message in the Vista event log "system failed to log in on node TAVISTA".
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 11:10 AM
Every 6 second there is an error message in the Vista event log from user "system" that "system failed to log in on node TAVISTA".
Vista 5.x
 The reason for the messages is that GetAlive is activated for Icarus( a program used in Sweden which sends SMS when a alarms comes to Vista).
Deactivate "GetAlive" for Icarus.
  • 11029
