Error generated when deleting Services in SP-C-Web
  • Error generated when deleting Services in SP-C-Web
  • AdamSteele
    AdamSteele
  • David_Kendrick
    David_Kendrick
Admiral David_Kendrick Admiral
‎2023-06-27 12:05 AM
on ‎2023-06-27 12:05 AM
An error is generated when trying to delete an unused Service in the SP-C-Web.
EcoStruxure Security Expert
  • SP-C-Web
  • Services
When using the Security Expert Client/Server and an SP-C it is possible to delete an unused/unwanted Service quite easily.
However when trying to do the same in an SP-C-Web via its web browser the following error is generated.
The SP-C-Web is fundamentally different to an SP-C with a Client/Server system.   As such deletion of Services from an SP-C-Web is not supported.  It is instead recommended to either stop the unwanted Service entirely or leave it running but without association to any Areas.
  • EcoStruxure Security Expert
  • DavidKendrick23
