Error 'The UPREV engine was asked to process an invalid code type' when flashing the firmware in the controller.
  • Error 'The UPREV engine was asked to process an invalid code type' when flashing the firmware in the controller.
  • GavinHe
    GavinHe
  • AbeMeran
    AbeMeran
‎2018-09-06 11:15 AM
Last Updated: Sisko GavinHe Sisko ‎2024-02-26 04:26 AM
Andover Continuum
  • bCX9640
  • CX9680
  • ACX5720
  • ACX5740
RAM issues
Using a browser login to the controller and perform a 'Clear Database Backup', commit changes and restart the controller.
When the controller has re-started  disconnect the battery, power down the controller and after a minute power the controller up and re-connect the battery.
Wait for the controller to come back online and then try the uprev operation once again.
Tags (4)
  • 10864
  • GavinHeward24
  • still does not work
  • this problem is only on units that show 0.0000000 version
0% helpful (0/1)
