Error Getting IIS object: IIS://LocalHost/W3SVC/1/Root/webclient. Automation error Invalid syntax when installing webclient
  • Error Getting IIS object: IIS://LocalHost/W3SVC/1/Root/webclient. Automation error Invalid syntax when installing webclient
  • Ramaaly
    Ramaaly
  • Jonathan
    Jonathan
  • Alan_Wood
    Alan_Wood
‎2018-09-06 01:21 PM
Last Updated: Lt. Commander Ramaaly Lt. Commander ‎2025-09-03 11:06 AM
Andover Continuum
  • Webclient
  • Windows XP
  • Windows 7
IIS must be installed prior to webclient or the webclient applications cannot be created
1. Install IIS prior to the webclient install (See the installation guide section Pre-installation Microsoft Tasks)
2. If IIS is already installed, run the following command from a DOS prompt (Start>Run>cmd)
CD\ + enter
Cd \Windows\Microsoft.net\Framework\v2.0.50727> aspnet_regiis.exe -i + enter
Reboot the PC and reinstall webclient
Windows 7: Ensure that all the specific IIS components are selected according to the webclient installation guide
See the section Configuring IIS for Windows Vista and Windows 7. There are specific components that must be selected in order for the webclient applications to work properly. If a component was missed, select it, then restart IIS and Continuum.
Tags (15)
  • 6067
  • access
  • activation
  • dcom
  • dotnet
  • explorer
  • firewall
  • internet
  • launch
  • permissions
  • ports
  • RamaAly25
  • server
  • settings
  • ssl
