Error: Cannot initialize view.., encountered while accessing an UNC station recently added with the SnmpService
  • Error: Cannot initialize view.., encountered while accessing an UNC station recently added with the SnmpService
  • RyanSuar
    RyanSuar
‎2018-09-06 12:24 PM
Encountered the following error while accessing an UNC station recently added with the SnmpService
java.lang.IllegalStateException: tridiumx.snmp.services.SnmpService: releases incompatible [2.302.532.v1 != 2.301.431.v1]
I/A Series R2
This is caused by the version of WorkPlace Pro software used. WorkPlace Pro software version r2.301.431 was being used to access an UNC station with SnmpService version r2.301.532.
Use WorkPlace Pro version 2.301.5xx and above to access the UNC station.
  • TAC IA Series
  • 7833
