Error 5295 or invalid attribute when applying installing an xdriver
  • Error 5295 or invalid attribute when applying installing an xdriver
  • Alan_Wood
    Alan_Wood
‎2018-09-06 02:26 PM
xdriver
Clicking apply prior to installing the driver will present the 5295 error.
One of the following should resolve this:
  1. Make sure that you click "Apply" prior to checking the driver .
  2. Do not map a drive to the server, place the driver on a local Cyber and do not place any spaces in the path.
  3. Ensure that the correct driver is being used.
  4. Set the commport to xdriver, install the driver then apply. If you hit apply before you install the driver you will get the 5295 error
  • 3970
