Error 0x00001402 (Reached end of the list).
  • Error 0x00001402 (Reached end of the list).
  • PaulFr
    PaulFr
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 09:55 AM
A Plain English program is becoming disabled.  The controller error log logs the following error.
0x01402 (Reached end of the list).
Continuum
Plain English
Error
b3
i2
0x00001402 (Reached end of the list) is a Plain English error.  This error most often occurs when a program is calling a Plain English Function that contains no byte code..
Edit each InfinityFunction in the controller to determine which function is empty (contains no programming).
Labels (2)
  • 14876
