Erie Actuators Part Numbers with '-Z'
  • Erie Actuators Part Numbers with '-Z'
  • RobertAndriolo
    RobertAndriolo
  • RyanSuar
    RyanSuar
Admiral RyanSuar Admiral
‎2019-11-20 02:06 PM
on ‎2019-11-20 02:06 PM
Need to replace discontinued Erie actuator model AH13U020-Z but unsure if the current model AH13U020 can be used as a direct replacement
Field Devices
Erie actuators
Unable to find any documentation for the AH13U020-Z
The '-Z' models for the Erie actuators indicates it is the Made in China version of the actuator. We have since stopped manufacturing the actuator in China.
The AH13U020 can be used to replace the AH13U020-Z
  • Field Devices
  • RyanSuar19
100% helpful (1/1)
