Equalization on Windows XP PCs for I/NET Seven Revisions 1.10 - 1.14.
  • Equalization on Windows XP PCs for I/NET Seven Revisions 1.10 - 1.14.
  • Roger_Bently
    Roger_Bently
‎2018-09-06 03:28 PM
File Equalization not working even though I/NET indicates Equalization is online.
A balloon message pops up saying that Equalization is Online but the data is not shared between Client and File master.
Windows XP
I/NET Revision1.10 - 1.14
There is an issue with Equalization when using Windows XP as File Master and Clients with I/NET Seven Revision 1.14. Once a Client is connected to the file master, a balloon message pops up saying that Equalization is Online, but it never gets the snapshot from the File Master.
To correct this issue the following will apply:
  1. Verify that the user has full access right on their Windows user Password.
  2. Go to My Network Places, Right Click and select Properties.
  3. Select the Advanced Tab, verify that there are no checked boxes for the Firewall.
  4. Go to Administrative Tools, Local Security Settings.
  5. Local Policies, Security Options,
  6. Locate the policy "Network Access: Sharing and Security Model for local Accounts"
  7. Change the security setting to "Classic – local users authenticate as themselves".
  8. Apply changes, shut down and restart the PC.
  • TAC INET
  • 1006
