Epibuilder field expression limitation in layout properties card encoding
  • Epibuilder field expression limitation in layout properties card encoding
  • Alan_Wood
    Alan_Wood
‎2018-09-06 12:58 PM
There is a 24 character limit for an expression when entered through Epibuilder>layout properties>Encoding> Field Expression
  • Cyberstation
  • webClient
  • Windows XP
  • Windows Vista
  • Windows 7
  • Windows Server 2003
  • Windows Server 2008
ImageWare EpiBuilder has limited this way of entering in the expression, but offers another method for a work around.
To work around this limitation issue.
  1. Define the expression first in the following place Edit> Define Expression
    Ex. [Info1]+[Info2]+[Info3]+[Info4]
  2. Click OK
  3. Layout Properties> Encoding> Field Expression
  4. The drop down now contains [Info1]+[Info2]+[Info3]+[Info4] which could not be entered directly.
  • 6775
