Entry Point Not Found
  • Entry Point Not Found
  • Roger_Bently
    Roger_Bently
‎2018-09-06 02:50 PM
Error "Entry Point Not Found" when starting I/NET
I/NET
One or more .dll files have been overwritten by another Windows Application on the PC
  1. Verify that the I/NET files .exe and .dll are all the same build by doing a right click, properties and check the version tab
  2. Save all files and graphics, then reinstall I/NET again to put back the correct rev of. dlls that are compatible with the I/NET Software.
  • TAC INET
  • 2949
