Enthalpy Scheme for MicroNet Controllers
  • Enthalpy Scheme for MicroNet Controllers
  • CraigEl
    CraigEl
  • Gary
    Gary
‎2018-09-09 10:03 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-25 11:16 PM
MicroNet controllers using VisiSat do not provide a direct enthalpy value. The existing enthalpy object in Bubbleland only outputs a digital state based on comparison logic, which is insufficient for applications requiring actual enthalpy values.
Satchwell MicroNet
  • Satchwell MicroNet
  • VisiSat
The Bubbleland stencil includes an enthalpy object that provides a digital output (on/off) based on temperature and humidity comparisons. However, it lacks a standard object to calculate and output a true enthalpy value.
Option 1: Create a Simple Bubbleland Scheme
  • Use temperature and humidity as dynamic inputs.
  • Use fixed values for other parameters (e.g., pressure = 1 bar).
  • This provides an approximate enthalpy value.
  • A downloadable custom object is available to simplify this process.
🔗 Download Enthalpy Custom Object.zip
Installation Instructions:
  • Unzip the file to create a Satchwell folder.
  • Copy the folder to your C:\ drive.
  • Files will be placed in the correct VisiSat directories automatically.
✅ Option 2: Use Preconfigured Controller Schemes
  • Download configuration files for your specific controller model.
  • Load the scheme with enthalpy objects directly into the controller.
📦 Available Downloads:
  • Custom Enthalpy Scheme 300.zip
  • Custom Enthalpy Scheme 350.zip
  • Custom Enthalpy Scheme 440.zip
  • Custom Enthalpy Scheme 450.zip
  • Custom Enthalpy Scheme 500.zip
  • Custom Enthalpy Scheme 550.zip
  • Custom Enthalpy Scheme 620.zip
  • Custom Enthalpy Scheme 650.zip
✅ Option 3: Use a Prebuilt VisiSat Project
  • Includes all controller types with enthalpy schemes.
  • Configuration files are saved under a Configs folder within the project.
📦 Download Full VisiSat Project (4.2 MB)
Additional Notes
  • These schemes are intended to provide estimated enthalpy values for operational use.
  • For precise calculations, consider integrating external sensors or software.
VisiSat 2.1 Enthalpy Scheme.zip
Tags (2)
  • 5269
  • CraigEllis25
