EcoStruxure Trend Log is not visible to EcoStruxure Energy Expert (formerly Power Manger) ETL Tool
  • EcoStruxure Trend Log is not visible to EcoStruxure Energy Expert (formerly Power Manger) ETL Tool
  • David_Kendrick
    David_Kendrick
  • DavidChild
    DavidChild
  • Benji
    Benji
‎2020-12-09 05:55 AM
on ‎2020-12-09 05:55 AM
When mapping the EcoStruxure Building Operation (EBO) Trend Logs to EcoStruxure Energy Expert, not all trend logs are visible in the ETL Tool 'Load Sources'.
  • Energy Expert
The EBO user credentials entered into ETL for connect to the EBO Database must have access to BOTH the trend log itself, and the point which the trend log is logging.
Edit the EBO user which the ETL is using to connect to EBO and give a minimum of Read Only access to both the Trend Log in question and the Point being logged  and then in the ETL re-run 'Load Sources'.  The additional points which were missing before should now be available for mapping
Tags (4)
  • 17914
  • DavidKendrick20
  • pm
  • pme
100% helpful (1/1)
