EcoStruxure Building Operation WorkStation Auto Login feature locked
  • EcoStruxure Building Operation WorkStation Auto Login feature locked
‎2018-09-06 10:39 AM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:39 AM
User of EcoStruxure Building Operation WorkStation used the "Remember me on this computer" option and logged into an account that does not have account rights to logout.
WorkStation
Warning
A situation such as this could happen either due to inattention of the user or because of planned system design (Kiosk with Building Operation WorkStation logged into a read only account). However it might be necessary due to maintenance to adjust the login option.
In the absence of a kiosk situation, it is recommended to always leave the ability for a user to logout by only hiding the toolbar instead of disabling it.
The solution can differ depending on the installation or usage scenario.
User has access to log off option
  1. Once logged into Building Operation WorkStation use the log off option to return to the login prompt
  2. Uncheck the "Remember me on this computer" option.
Enterprise Server on another computer or accessing an Automation Server
  1. Disconnect the Ethernet cable for the computer or disable the network port
  2. Building Operation WorkStation attempts to login returning user to the login prompt.
Enterprise Server on same computer
  1. The Enterprise Server can be stopped temporarily and the next attempt to start Building Operation WorkStation will result in a communication failure allowing you to modify the "Remember me on this computer" selection.
    This could result in loss of data while the Enterprise Server is stopped.
  2. Delete the Building Operation WorkStation configuration file (named either SBO.ClientUserProfile.bin or TAC.ClientUserProfile.bin for older versions) stored in the computer application data. Deletion of this file will result in loss of custom settings such as column widths and similar customizations.
Tags (2)
  • 12545
  • SharlinaRenwall22
