EPI Builder Camera License
  • EPI Builder Camera License
  • CraigEl
    CraigEl
  • sesa116827
    sesa116827
‎2018-09-11 11:53 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 09:38 PM
In earlier releases of continuum Pre Windows 7, The Badge software would attach to the cameras and import a photo directly to the Badge without any additional cost.
Canon's SDK for the Powershot cameras is not compatible with Windows 7
Canon's SDK for the EOS line of cameras is compatible with Windows 7 but requires  a license in order to import photos directly into the badge.
Andover Continuum
  • Windows 7
  • Continuum 1.94
There are a limited selection of cameras that are supported and qualified with Epi
  • Canon's SDK for the Powershot cameras is not compatible with Windows 7
  • Canon's SDK for the EOS line of cameras is compatible with Windows 7
See related article, An Epibuilder Plugin is necessary for some badging devices to work.
Camera (Face) Options:
Canon EOS Camera (high end cost / higher functionality)
  • Tested on Windows XP Pro SP 3 & Windows 7 Pro
  • Models currently tested: EOS Rebel XS and EOS Rebel T3
  • Interfaces through the EPI Canon EOS capture plug-in license
  • 13365
