EBO SAML Single Sign On(SSO) Reverse Proxy support
Send InviteCancel
Unable to configure reverse proxy for SAML-based Single Sign-On (SSO) in EcoStruxure Building Operation (EBO).
Building Operation Workstation
Building Operation Webstation
Although EBO 7.0 has enhanced reverse proxy support, this does not include SAML SSO and EBO does not support reverse proxy configurations for SAML SSO. This limitation prevents successful integration when a reverse proxy is used in the authentication flow.
At this time, EcoStruxure Building Operation version 7.0 does not support reverse proxy configurations for SAML SSO. This is a known limitation.
An enhancement request has been submitted to the Idea Forum to address this functionality in future releases.
To support this request, please visit the Idea Forum and click the thumbs-up icon on the SAML reverse proxy support idea to increase its visibility to the product management team.
