EBO Relative Path Permissions configuration
  • EBO Relative Path Permissions configuration
Lieutenant JG JamesMorgan Lieutenant JG
‎2023-12-13 01:54 PM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:32 AM
How to configure the relative path permissions
Building Operation Enterprise Server
Warning
Potential for Data Loss: The steps detailed in the resolution of this article may result in a loss of critical data if not performed properly. Before beginning these steps, make sure all important data is backed up in the event of data loss. If you are unsure or unfamiliar with any complex steps detailed in this article, please contact Product Support for assistance.
Relative path permissions help configure the path permission for multiple modules (i.e.100 AS-Ps) or many different folders
Here's how to give 'read-only' analog value permissions for 2 separate folders:
1. Go to Relative path permissions. Select the type of permissions desired (Full permissions for Analog Value/ NO permissions for Digital Value)
2. Go to the Local Account Group and select the Permissions tab. Under Path Permissions, add (+) the created path permissions to the desired folders. 'Folder' and 'Folder 2' are selected to have the same path permissions. Save and apply configuration.
3. When viewing the system tree, both 'Folder' and 'Folder 2' have read permission for Analog Value
  • JamesMorgan23
0% helpful (0/1)
