EBO Multi Trend Log Capture in XLSX/Excel format
  • EBO Multi Trend Log Capture in XLSX/Excel format
  • JohnBoehmer
    JohnBoehmer
  • Reza
    Reza
Lt. Commander Reza Lt. Commander
‎2021-04-20 08:24 AM
on ‎2021-04-20 08:24 AM
How to create a proper XLSX/Excel template under Alarm Triggered Notification of EcoStruxure Building Workstation, in order to receive the Multi trend logs report in the XLSX/Excel format.
Additional information is needed to create a template for presenting multi-trend log information in Excel XLSX format.
Below screenshot shows where users can select the Report format and XLSX template.
The multi trend log containing four Interval Trend Logs 1 to 4 with their time stamp is shown as below as an example
In order to get the XLSX multi trend log report in XLSX/Excel format upon receiving a trigger, the following XLSX template needs to be used containing two rows:
  • The first header row contains the column headers from the trend log.
  • The second row include the <Multi Log List> command
Here is final report in Excel/XLSX format:
Tags (7)
  • Excel format
  • Multi-trend log
  • RezaAmirzadeh21
  • RezaAmirzadeh22
  • spreadsheet
  • template
  • xlsx
34% helpful (2/6)
