Duplicate BMS System Data Source in Building Advisor
  • Duplicate BMS System Data Source in Building Advisor
  • PeterEdvik
    PeterEdvik
  • Katha
    Katha
  • JonGreen
    JonGreen
EcoStruxure™ Building Advisor
Lt. Commander Katha Lt. Commander
‎2025-03-11 01:44 AM
Last Updated: Janeway PeterEdvik Janeway ‎2025-03-11 01:44 AM
Attempting to update the System Identifier to align with the newly created ID in the EBO system, is causing a 'Duplicate BMS System Data Source' error.
EcoStruxure Building Advisor
Building Advisor
A duplicate ID has been identified in Building Advisor. This may correspond to an older system ID or one from a different site.
The error indicates the site where the duplicate ID is found, which usually corresponds to the site you are attempting to update.
- Go to the admin menu, select the site, then choose 'Clear' on the BMS System and click 'Save'.
- Click the pencil icon to add or edit the BMS System. Enter the new ID and then click 'Save'.
  • EcoStruxure Building Advisor
  • KatharineVasquez25
