Double-byte character set (DBCS) is not supported
  • Double-byte character set (DBCS) is not supported
  • RobertAndriolo
    RobertAndriolo
‎2018-09-10 10:55 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-08-12 08:44 AM
  • Can not import double-byte (2-byte) character from third party BACnet device receive error "Property invalid datatype"
  • Character support in Building Operation
StruxureWare Building Operation 1.2 and above
Building Operation supports various language characters as part of Unicode. These characters are usually received in UCS-4, UCS-2 or UTF-8 and sent in either UCS-2 or UCS-4. Double-byte format such as JIS X 0208 character set is not supported.
Here is a reference posted on Microsoft Developers Website: Double Byte Character Sets. The note (second paragraph) of this reference indicates that new applications should use Unicode and that DBCS is a legacy protocol.
There are no plans to support double-byte characters. It is recommended that a Unicode standard (UCS-4, UCS-2 or UTF-8) be used.
  • 11633
